LG WM2277H Front Load Washer Logo
Anonymous Posted on May 05, 2010
Error code of EE only the 1st E is missing the top bar
Manual just says to unplug and call for service.
Any suggestions
  • Anonymous May 06, 2010
    Are you saying that the problem is in the pcb board and I should replace it. If so what is the part # i should be looking for. Thanks Dean
  • Susan Scio
    Susan Scio Aug 07, 2014
    Dean, my washer is doing the exact same thing that you described. What did you end up doing? what was the problem? thanks
Anonymous
Level 3:
  • Master 5,081 Answers
  • Posted on May 06, 2010
Anonymous
Master
Level 3:
Answers
5081
Questions
Helped
2236532
Points
18738
Main board pcb would cost about $152.00...Just for the part...Part# 6871ER1104A
You have to replace this to rectify the problem of your washer.
Please donot forget to rate and accept my answer.
Mukesh Kumar
Level 3:
  • Master 3,230 Answers
  • Posted on May 05, 2010
Mukesh Kumar
Master
Level 3:
Answers
3230
Questions
0
Helped
903205
Points
9207
Well Error code EE means (EEprom error) Cause: EEprom is out order. Displayed only when the start / pause button is first pressed in the OC test mode. means there is some problem in the Main Board pcb and it would cost about $150. You need to remove the three screws in back, at top. Slide cover back, PCb is mounted to back wall. Please post comments for further help or information........
Good Luck!!
Thanks
EE Fault code means
make model (what it is) is needed for all questions, or we have to guess!
The EE error code indicates an error on the main control board. This error code is usually fixed by unplugging the washer for 10 minutes to clear any memory errors on the control board.May 3, 2017
LG Front Load Washer EE Error Code - How To Repair?
Haier Wine Cellar, Dual model, displays EE error code and was heavily iced on the interior back.
If the refrigerator or freezer displays error code, request a technician to check, please call the service
Different series display different error codes.
The error codes for the refrigerator: F1, F2. F3, F4, F5, F6, F7, EO, E1, E2, E6, Er, Ed, an so on
The error codes for the wine cellar: F1, F2. F3, F4, F5, H1. H2, A1, A2, E1, E2, EE, HH, LL, and so on
Notice: If you power off then power on, maybe the error code disappear, but it will display again after a few hours.
List of error codes wm2496hwm
The tE error or fault code indicates that you have a defective water temperature sensing thermistor. The thermistor cannot be repaired and will have to be replaced.
My Toyo Laser 30 has an error code EE 5 and I can't find any info on that particular code. Help?
Call manufacturer or Installer - Direct Vent Furnaces are not a DIY service. Carbon Monoxide is deadly and can easily be emitted if there is something wrong with the heater. Get professional help before anything further is done, as it needs a full inspection for your safety.
2answers
There is an EE code. The machine just beeps.
EE
Remove your washer from the power source if you see an "EE" error code, where the first E is missing the top part of the letter. Your washing machine has a serious malfunction, and you must contact a technician.
A bit odd that as error code EE does not exist for washing machines, it's a refrigeration error code. Unless of course part of the display (led) has been damaged and the code isn't displayed properly.
Hope helps.
Washer has a LE (or EE) code or something like that. First character looks like an E missing the top bar, or an L with an extra bar in the middle. i was doing a load of towels when this happened. i assumed...
Washing machine has an LE error code
Is this a new installation? In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
4helpful
ERROR CODE 5200 PRINTER ERROR HAS OCCURD TRIED EVERYTHING ,UNPLUGED ,REMOVE INK CARTRIDGE ETC. STILL NOT WORKING
Error 5200 is a service error
Follow this solution step by step
  • With the printer turned on, unplug it
  • Open the top and bring the ink cartridge holder to the middle
  • Raise the gray bar and remove the print head assembly with the cartridges in it
  • Lower the gray bar with the head missing and close the top with the head out
  • Restore the power,wait till the printer starts
  • It will tell you to put in the cartridges
  • Refit the print head, close the top and the printer should resume working
This is a commonly mentioned fault/fix, hope it helps
2helpful
Error message
EE error code with the top of the E missing is due to a faulty Thermistor.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
