Trimmer will only run in choke position
You have a few possibilities. Make sure you have good fresh gas in the tank. You're not getting enough gas, so choking helps get more gas than air, making it run better. Could be the carb diaphram (not very expensive if you replace yourself), when they get old they don't perform like they should. Could be the filter in the gas tank is bad, plugged. Also might be just an easy adjustment on the carb Low, and High speed screws. The choke has three positions, full choke, partial choke, and no choke, which means run position.
Have to put on choke to start as well.
