Whynter FX-6SW Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D Logo
Posted on May 03, 2010
Just want the cold water - Black and Decker 900144
Hey, I leave the thing unplugged because it is constantly heating up water, but I never use it. Especially because it's almost summer.
Does any one know how to disable it from making hot water, while still cooling water? Is the little while screw on the back the thermostat?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1046
Points
I need to do the same thing. Please let me know if you were able to get this done. It would help me out alot. Thanks you.
3answers
"Standby" on Digital Screen
Leave It Out To Fully Dry Dont Plug In or You Mite Damage The Chip Board
Do you use hot or cold water. It doesn't say in the manual
I have used both hot or cold water....but have found that hot water works best to rinse the starch off and also makes the cooking process go faster...
Here is a tip that will help you figure out about using a rice cooker...
How much Rice and Water go in the Cooker
heatman101
We have a black@decker stainless dome kettle (red) electric kettle. we've used it for a couple years and it works great, but there are deposits inside basin that we can't get off with soap/water. they're...
Fill it with vinegar and leave to soak overnight/for two nights if really bad.
Any parts which are impossible to fill with vinegar - lids/spouts, soak a cloth or tissue in vinegar and wrap/wedge into....and leave to soak overnight.
I have a black/decker drill Fire/Strom 12V When I pug the charger into the electric outlet the light doesnt come on. So I leave it in but the battery never get charger. is it the charger or the battery.
How old is the battery there olny good for 3 or4 years and if you leave themin the cold they won;t last half that long yours is an older one the battery dosn;t come off it although i like black and decker i would have to say even if it was the charger and you got a new one the battery wouldn;t live vary much longer
Problems with Black & Decker #900144 TopLoad Water Dispenser: It is dripping water constantly and the item is only 4 mnths old
you have to open it up and look where the water is dripping from. it could be from the rubber hoses that connects the tank to the faucets.
if it's on the hoses, that would be easy to replace, but sometimes the leak would come from the stainless tank whiich would be very hard to replace.
tnx 4 using fixya,
drcool
2answers
Iron D2000C type 1 black decker
the folowing reason for not working 1. the connection may be lose 2. the heating coil is gone 3. inside connection may be lose.
3answers
Black & Decker TCM700 Coffee Maker problem
All coffe makers have a thermal cutoff fuse located on the bottom heating plate. It is usually in series with one of the leads to the actual heater. This should read "short" with an ohm meter. If it is "open" it needs replacement. They are rated in Degrees celsius, and are sometimes difficult to find. Black and Decker may be able to send you one.
Top Whynter Water Filters & Coolers Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Whynter Water Filter and Cooler Expert? Answer questions, earn points and help others
