Whirlpool GGQ8831L Gas Dryer Logo
Posted on May 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No heat whirlpool electric dryer imperial 70 1986 vintage
Unit has 240VAC, unit runs but no heat. 10 ohms (continuity) across heater element, and operating thermostat and heater box (lower on heater box) thermostat have continuity. cut off switch at top of heater box has NO continuity.
Anonymous
Level 3:
Genius:
  • Master 1,122 Answers
  • Posted on May 03, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1122
Questions
5
Helped
316702
Points
2771
Replace cut off switch fuse at the top of heater box
1helpful
2answers
Have a Hotpoint Electric dryer. Does the timer in this have breaker points to send voltage to the elements?
Most machines offer a thermal device connected before the element, where, depends on the manufacturer and the vintage. I the system over heats and or is too wet, it will shut down the element before the element burns out.contact the manufacture, on the net, then click on support and request a pdf. manual of that machine.It shall direct you to the parts page. Then do as we all do, get out your volt ohm device and test the items.
Good luck.
All of the fuses check out element is good all conections good but no heat
There are 5 switch-like elements in series with the heater element, according to one diagram I found (Google "kenmore 80 dryer wiring diagram"). If any of these is open you won't get heat. If you're handy with a VOM, it's any easy problem to track down. Start at the element -- you should see 240VAC across it. If you do, the element is bad. If you don't, check across all the other switch-like things. You should read 0VAC across each of them if they're closed (good) or open (bad). It's a relatively easy matter to find a single open element, slightly more complicated if there are several.
Or, start across the 2 240VAC line legs. You should read 240VAC; if not, your problem is outside the dryer (circuit breakers DO fail). If so, there is an open somewhere in the circuit preventing current flow. Move one of your VOM test leads through the circuit from that 240VAC leg all the way around to the other leg. It will continue to show 240VAC until you pass over the open element (a switch-thing, a bad piece of wire (unlikely), or the heater element), at which time it will show 0VAC. When that happens, the problem is in the element you just passed over. If you're lucky, it will be an easily-replaced part.
2helpful
Electric Heating Element
No continuity would mean the element is OPEN, or showing an infinite resistance reading. If the element were SHORTED, it would read 0 ohms. These elements are supposed to read 9 to 13 ohms if good. Double check and make sure have your meter scale set correctly. You should be taking resistance checks on the lowest scale of Rx1.
If you have confirmed the element is defective, and the model dryer is correct, the element should pull out of the heater box by removing two screws on the left hand side of the box. You will need to remove the thermal cut-out (TCO) and hi-limit thermostat in order to accommodate removal of the element. These are the two components that are mounted on the side of the heater box. You leave the wires connected, and simply remove any mounting screws that hold them in place. This will keep the element from coming out of the heater box.
If these instructions are not clear, please post back with your MODEL NUMBER so I can understand how your dryer is configured.
If your dryer runs, but does NOT heat, the following two links can give you some added advice on how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
http://www.fixya.com/support/r3574266-thorough_dryer_advice
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts (if required) can be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify the parts you need. The heating components are usually listed under the "Bulkhead" section.
Read through the information I provided and, if you have any questions. I'm assuming this is a Whirlpool Electric Dryer, because of the illustration you posted the question under. I hope you find this information is helpful.
If you would like some added advice that can help you in the future, Repairclinic.com has a repair manual that you can purchase that you can to help repair any Whirlpool manufactured gas or electric dryer. The part number is 1159257.
2helpful
Kenmore electric dryer model number 86860100 dryer not heating.....cleaned out vents not the problem....everything else seems to work.. I had seen in the past it glow in back of the dryer so I turned out...
hello there:
Testing with an ohm meter checking on a dryer....
These are the places that pass voltage to the heater elements on an electric dryer. In order to check a dryer for no heat, here is a list of places to check. Remember to always unplug the appliance before starting testing with an ohm meter. Always remove wires from the part you are testing with an ohm meter ( write down what goes where first before removing any wires ).
Meter testing and usage tips.
1. Power supply-check power supply at terminal block where cord enters the dryer. Should read 240V. If you read 240V here, tested with a volt meter, unplug dryer and test components with ohm meter.
2. Thermostats-Cycle and safety thermostats-read them with an ohm meter. Should show continuity . How common thermostats work.
3.Timer-The timer has a set of contacts that pass voltage to the heaters. If you can not determine by wiring picture what they are, check across the two terminals with the largest wires on them. The heater wires are almost twice as large as the others. You should read continuity with timer in heat mode.
4. Thermal fuses-In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element.
5. Selector Switches-Read the wiring picture and determine which switch is closed. You should read continuity across closed switches.
6. Safety Switch on Motor-There is a safety switch on motor to insure that heaters can not come on unless motor is running. It is normally open when the motor is idle/not running, and closes when motor runs. In order to check with an ohm meter, remove the two large wires on motor switch and make them electrically safe. Tape them. Plug the dryer in and start motor. Check continuity across the terminals on the motor switch you removed the heavy wires from. If it is ok you should read continuity. Remember that the smaller wires in a dryer carry the 120V and the large wires carry 240V. There is no voltage on these two terminals with wires removed. It is ok to test with ohm meter.
7. Heat elements-Test heater element with an ohm meter. You will read continuity across a good element 8-12 OHMS
3helpful
The dryer is not heating
Hello there here is a list of things to check
7. Heat elements-Test heater element with an ohm meter. You will read continuity across a good element ( 8-12 ohms is an average element ).
But darn it, I don't have a Ohm Meter....
To check the thermal fuse - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only. To check the thermal cut-out - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
To check the thermostats for continuity - - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
How to take apart information for GE style dryers
How to take apart information for Inglis - Whirlpool - Kenmore dryers
How to take apart information for Maytag dryers
How to take apart information for Frigidaire and White Westinghouse
Jan 09, 2010 • Dryers
2helpful
It keeps running non-stop but wont heat up
Your temperature thermostat or heater coil is most likely bad, you can test by ohming each. NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
12helpful
2answers
My Whirlpool Imperial Series Dryer is 4 years old. NO Heat.
Sure there is. The cheapest I have found is on amazon. click here Dryer Heating Element 279838 For Whirlpool Kenmore and take a look. I hope this was helpful. cheers
Sep 07, 2009 • Dryers
Clothes dryer not producing heat
Check voltage at the receptacle first. The motor and timer operate on 120VAC. The heating element requires 208/240VAC to operate. Remove power from the unit. You can check the heating element, thermostats and thermal fuses using an ohm meter across each components terminals with one wire removed. The thermal fuses and thermostats should read zero ohms. The heating element will read low ohms (20 to 40). Successful heater operation still depends on the motor centrifugal switch being closed. Depending on the model, you need the heat circuit in the timer or electronic control to be closed.
I hope this helps you.
Kitchenaid superba dryer won't heat Where is the heater fuse located?
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
7. Heat elements-Test heater element with an ohm meter. You will read continuityacross a good element ( 8-12 ohms is an average element ).
To check the thermal fuse  - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.To check the thermal cut-out  - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
How to take apart information for Admiral, Norge, Magic Chef and Crosley
2answers
Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
