LG LHD65EBL Dehumidifier Logo
Posted on May 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Runs - but no water in bucket
Only two years old!
Anonymous
Level 3:
  • Master 10,865 Answers
  • Posted on May 02, 2010
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3799915
Points
33142
Hello. If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
5 Related Answers
Anonymous
  • 43501 Answers
  • Posted on May 05, 2010
SOURCE: The dehumidifier runs but no water is in the bucket
There are many reasons for a dehumidifier tto not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Anonymous
  • 57 Answers
  • Posted on Oct 07, 2009
SOURCE: Machine works, but no water collecting
A dehumidifier is basically a cooler. The condenser coil on the outside should feel cold to the touch usually around 34 to 38 degrees, as air passes over the coils they collect the humidity in the air and it then drips down into a collector tray. If the coil does not feel cold it is ether a bad control switch not letting the cooler (compressor) turn on, low on freon, or burned out compressor
Anonymous
  • 43501 Answers
  • Posted on Apr 30, 2010
SOURCE: My dehumidifier LG LHD 45 EL runs, but does not
Here is a tip that I wrote about that problem...
heatman101
Anonymous
  • 229 Answers
  • Posted on Jun 27, 2011
SOURCE: My dehumidier is not pulling any water into the
If the unit is not pulling water into the bucket its probably not that humid in that area anymore. If it aint broke dont fix it.
Anonymous
  • 43501 Answers
  • Posted on Aug 13, 2011
SOURCE: Our dehumidifer runs and runs
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
My dehimidifier is two years old in my basement. It runs, but there's never a drop of water in the bucket.
heatman101
Our dehumidifer runs and runs and there is no water in the receiving bucket. The settings are at 55%. Any suggestions? It's about 4 years old.
heatman101
My dehumidier is not pulling any water into the bucket. Runs fine. About 1 year old.
1helpful
I have a LHD65EBLY7 that is a few years old. Turned it on this year and it runs but collects no water.
heatman101
1helpful
Product Goldstar Dehumidifier GHD30: Machine runs when red button is depressed by hand. Return water bucket and machine stops. Set theromstat controller on max, and when button is depressed it works and...
Hi
You need to check that the bucket is clean and that the sensor for the water level in the bucket is clean.
An old toothbrush and some warm soapy water can sometimes achieve a great result.
Failing this you may need a new sensor, be careful and either draw or photo the old wiring route with your cell phone to make it easier to fit the new sensor
Hope this helps
Gordon
Our dehumidifier is only 2 years old, runs, but does not collect water.
heatman101
The unit runs but does not collect any water
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
1helpful
heatman101
DH runs but does not condense any water out of the air (bucket is dry). This unit was working well until a week or so ago when we had a lot of T-storms and humidity rose considerably. We went from having...
there are coils in the unit that the water folws across, you can take the filter out and clean the coils, this would help,but even though it is only 1 year old it can go bad,, if it is clean inside and everything is appering to be working it might have just gone bad and n eed a new one
Top LG Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
