Leaking Water There is a pipe on the left hand side(looking from above..top of machine removed)near the bottom of the machine,which during a cycle constantly pours water.It looks like an overflow pipe,but why is it leaking.The machine is nine years old.The model is a novotronic wt 945.Any help much appreciated. Thanks.
  • 185 Answers
If there is a clamp on there try tightening it up or put a new clamp on it
Posted on Mar 25, 2008
6ya staff
SOURCE:
Front loader leaking underneath in the back corner on the left hand side
If its leaking during the fill cycle, its one of the water valves (solenoids) or associated hoses, loose clamps, etc. If its leaking during draining its the drain hoses, pump, clamps etc. Easiest way to tell. Pull it out, if you can remove the back, run it and look for the leak. Just don't touch anything while its running, you don't want to lose a finger or get electrocuted.
Aug 06, 2014 | Samsung Front Load Washer Control Board...
Water leak left side bottom @ beginning of washing cycle
If this leak only occurs at the beginning of the wash cycle, (and it would happen at every water intake), the problem would be between the water inlet solenoid valve and the drum. You do not give any description of your machine, but your would need to open the machine so that you can view the machine during the filling action and watch for where the leaks is. It could be a cracked pipe of a fitting come loose. Have a look first if there are any panels that can be removed from the back of the machine or perhaps the top. Take care, to fill the machine the power will have to be on and there will be terminals and connections that will be live. If you need the assistance of a flashlight, make sure that it is a non-conductive one and keep hands etc well clear while the power is on.
Apr 24, 2011 | Dishwashers
I have a kenmore top load washing machine model 110.92597200 that started leaking during the rinse cycle. The drain pipe isn't leaking and the water line hoses are just a few months old. They were both...
most likely is the water pump. you need to remove the cabinet to get to it and is at the bottom center. a white looking part. the shaft seal is bad.
Feb 09, 2011 | Washing Machines
Water leaking during wash cycle. How do you get access to inside
I use a putty knife about 2" inward , between the top and the front panel on each side . Give a good hit on one side while slightly pulling the front panel forewafd . Then do the other side . The front panel tilts foreward and hinges on the bottom with tabs . Then lift to remove .
Aug 02, 2010 | GE WBSR3140DW Top Load Washer
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
Water leaking from bottom ofoasis top loading machine
you may not be leaking out the bottom. Your stand pipe may be clogged. If the stand pipe has a slight clog in it, the stand pipe will over flow, and the water "looks" as if its leaking from the bottom... These pump faster than your old machine, so the pipe will back up faster... hope that helps
Jul 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Leaky drain pipe
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 12, 2009 | Washing Machines
Kenmore 417 series washer leaking
Feb 26, 2009 | Kenmore 43142 Front Load Washer
BOSCH SMS4472GB/20 DISHWASHER water leaking from vent/overflow hole in plastic next to flot on side of machine on third fill up
Remove the side and top panels of the machine.
On the left hand side you will see a clear plastic panel full of tubes and small tanks. This is the metering tank. At the bottom left of this unit, is a black pipe held on with a clip. There will almost definately be a blockage between this point and the sump. You can either buy and fit a new pipe or do what I did with mine, which was to remove it and clean it with hot water and a bottle brush. Seems to work like new again now.
You'll have to get the machine onto it's right side to remove the lower end of the black pipe from the sump. I drained as much excess water as possible out of the machine by sitting it on bricks, tilting it to the left and catching the water in a dish as it came out of the float hole. Some will also come out of the funny plastic tube which runs across the top of the machine - I carefully removed this first and caught this water in a pan.
Drain the waste pipe and disconnect the water supply.
Replace the right side casing on to protect the feed to the upper spray unit and put the machine on it's right hand side. Once the machine is on its right hand side, fin the water inlet valve and carefully remove its bracket from the chasis of the machine. You will need cross head and a torx screwdrivers - one for each screw. Once this is loosened, push some of the water supply pipe into the machine so you can move the bracket to the right a little to gaine access to the waste pipe. Remove this by removing the two gold coloured screws. This should now give you easy access to the sump end of the black pipe which lead from the metering tank. Remove this and clean it out. Pop all the parts back, stand you machine upright. Reconnect the watre supply and the waste and give it a rinse cycle to test - number 1 on the dial.
Hope this helps. My apologies if any of the take apart is not completely accurate - I don't want to turn my machine over again to check!
Mark
Jul 07, 2008 | Dishwashers
Water coming from bottom of machine
If this only happens when the machine is filling the hose leading to the top of the tub may be leaking. Before it fills this hose is disconnected from the water supply by a closed solenoid valve. There are two valves which feed into a common hose that comes up to the top of the tub where the water runs into the tub. The leak does not happen after the tub fills because all the water leaks out and no new water runs in. These hoses are usually very small and very inexpensive and held on with clamps. They can usually be replaced by removing a small panel near the hose attachment location.
Nov 30, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
149 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
