Had same problem. fan quit working. just needs lubrication and a nudge.
joyce
You have to pull off the rear cover inside the freezer and check to see first if you have an ice blockage secondly to see if your fan is running if you have no ice blockage and the fan is running then you might have to call a technician to check the t-stat,heater, and damper control as well if you have a meter and can check for continuity in the t-stat and heater id look for the fan and ice blockage first.
