Whirlpool Calypso GVW9959K Top Load Washer Logo
Posted on Apr 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a whirlpool top loader and i recently changed the coupler now the machine runs for a little bit then it shuts off and does nothing ill play around with the switchs and then i get it togo back on (not sure if that is actually doing anything) then it shuts down again motor feals pretty hot and at some point when it does run i can leave the top open and not hold the lid switch and it stays doing its thing can anyone help
Anonymous
Level 2:
  • Expert 64 Answers
  • Posted on Apr 24, 2010
Anonymous
Expert
Level 2:
Answers
64
Questions
0
Helped
14049
Points
128
It shouldn't run with the lid switch open I would try another switch or bypass it and see if that cures the problem It should fill with lid switch open.
How do you get to the washer belt? I think it is not spinning. I think it came off the pulley.
Is your machine a front,or top loader, if top loader the most typical problem will be the motor coupler,Is it makes a clunking noise that makes a think the belt has come off? if yes noisy watch this youtube video and it will show how to get to and replace coupler.
http://www.youtube.com/user/RepairClinic?v=9K1KHEogf3c&feature=pyv&ad=5453897861&kw=washing%20machine%20coupler
i hope my answer helps you to figure out what is wrong with your washer,
Gene
I have a top loader and replaced the coupler, now the drum is unbalanced when spinning, how do I re balance it. The technician says its a simple job but will not tell me how
If you had the washer tilted back when you replaced the coupler, this may just be a simple matter of releveling the washer. Whirlpool top loaders have an auto-leveling mechanism on the back two feet of the washer. Periodically, you may need to check the level due to normal vibration and moving the appliance.. The following link explains how:
http://www.fixya.com/support/r3868923-level_whirlpool_top_loading_washer
If the washer is unlevel it can give the appearance of the drum being tilted. Try this and let me know if this helps you. If not, please post back and let me know.
1helpful
Whirlpool direct drive top loader will not spin
Hi, Is the humming noise coming from the timer area? Do you know if it agitates ok?
When you have it in spin cycle, Try lifting the lid and see if the hum stops.
The reason for these questions is that on this model, if it drains the water out but does not spin, it is either lid switch, coupler, or transmission.
If it's the coupler, it will not agitate either.
Please let me know so I can assist you further.
Thanks
Vic
1helpful
Whirlpool washing machine (model LLR 9245 B) does not work
If it's a top loader, the coupler is broken. It's located between the motor and the gearcase. If you put it in spin and hear the motor run, this is your problem. It drains because the pump is mounted on the opposite side of the coupler and will be un-affected
2helpful
4answers
Whirlpool Top Loader LSB6000PQ0 fills up with water but that's it
you probably closed the lid to hard and broke the switch that tells the machine that it is closed. So the machine thinks the lid is open and for saftey reasons will not operate. I had the same problem. You can buy a new switch for about $10 or you can simply cuts the wires for the switch and wire them together. If you do this be warned that the machine will never know if the lid is open or closed. The machine will assume that the lid is always closed. But it will work also.
WASHER WON`T FILL FULLY WITHOUT RE OPENING TOPLID SEVERAL TIMES?
water valve should be a single unit consisting of a hot and cold solinoid assembly. This whole valve assembly should be replaced.
Whirlpool top loader washer LSR7233EQ0 drains, but does not spin. Best troubleshooting advice?
You probably broke the coupler between the motor and transmission. However If it agitates the coupler is not broke.
Wife just told me this
try a new drain pump make sure there is no foriegn objects in there
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
