Kitchen Ranges Logo
Anonymous Posted on Apr 23, 2010
Can you please send me the directions to change the light bulb in my Kitchenaid Microwave Oven model # kemc308kss01?
  • Anonymous Apr 23, 2010
    Can you please send me the directions to change the light bulb in my Kitchenaid Microwave Oven model # kemc308kss01? The first response I received was how to change the oven bulb not the microwave bulb.
Shehu Pro
Level 3:
  • Master 1,284 Answers
  • Posted on Apr 23, 2010
Shehu Pro
Master
Level 3:
Answers
1284
Questions
Helped
334418
Points
3802
Hi, just follow the instruction below...
1. Essentially, open the oven door and remove the plastic vent strip between oven and microwave (4 screws). There will be 2 screws under that which secure the microwave unit to the frame. Remove those...
2. Open the microwave door and remove the plastic vent shield at the top (3 screws). At that point, the microwave unit will slide out from the frame as describe above. The light is to the rear of the large silver pad (I removed mine to facilitate reaching the light). If you look at the parts diagrams online, it will be obvious what to look for. I have the light out and sure enough, OSRAM 64405S....
Took me maybe 5 minutes to remove...
Take care
Charles T Nevin
Level 3:
  • Master 4,070 Answers
Charles T Nevin
Master
Level 3:
Answers
4070
Questions
0
Helped
1087975
Points
13055
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven.
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
How do I change light bulb in Kitchenaid Microwave KCMS1555RSS
You will need to remove the cabinet to change the bulb, the part number is 4359741, now the bulb is part of the base so the part number is the correct part for this model. Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
How to change the torsion springs in my kitchenaid microwave oven KEMC308KSS01
Replacing the spring isn't very difficult if you're mechanically inclined.
You're basically removing a few screws, the front panel of the door is removed exposing only the glass part that's still hinged. The springs are exposed. Hopefully one spring is still in tack so you can see the orientation of how to put the replacement in. It's not very intuitive on how to do this part.
Check this link for more details:
Microwave Repair
2answers
How do you change the bulb in a Kitchenaid microwave Model KBMC140HSS03
Hello & Welcome to FixYa
To replace the light bulb first remove the screws located on the vent grill at the top of the microwave, tilt the grill back and then pull away to remove. After this open the light cover , you have to remove the screws so that you can discard the old light bulb and then replace it with a new one. Please get back to me if you have any other questions.
Kevin
Hi there, unit worked fine this morning heating coffee, now has a different tone, and not heating. Timer works, interior light comes on, turn table rotating. Unit is a KEMC308KSS01
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
I have a Kitchenaid combo unit of Oven & Microwave. Model YKEMC308KM01, Serial # XP4603281.Can someone help me as to how to change the light bulb of the microwave. I simply dont see any openings on the...
That's covered on page 21 of your owner's manual.
If for some reason you don't have yours, you can download it free here.
To Replace:
Before replacing, make sure the oven is off and cool.
5. Reconnect power.
You can find handy exploded views and order parts by model number here.
2helpful
Microwave light is burnt out
Accessing the internal light bulb on model KBMC140HSS bulb will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool / Kitchenaid owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
These models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
26helpful
2answers
Need to replace light bulb in kitchen aid microwave
KitchenAid wants $58 for the replacement bulb. I bought it for $1.99 from www.lightbulbsdirect.com and it works just fine. The Item number is Q5G412V. It is a halogen 5-watt, 12-volt bipen G-4. Replacing the bulb requires some dismantling of the microwave. At first I was nervous about removing so many parts to get to the bulb but in the end it really wasn't so bad. The only tool I needed was a Phillips screwdriver. I surfed the net a eventually found instructions left by a friendly Blogger that guided me through the whole process. KitchenAid engineers were so STUPID when they designed this microwave. It takes two hours to replace a bulb that should take 5 minutes. Oddly enough, replacing the bulb in the normal oven below the microwave oven is a piece of cake.
Oven light bulb
Check your email
Jun 15, 2008 • Ovens
14helpful
7answers
LIght bulb burned out
I a Kitchen Aid Buit-in microwave (KEMC308KSS01) with the same problem - light went out. Can you send me the instructions on how to replace the bulb? Thank you! [email protected]
Top Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
