I've lost one of the harness pads for my Quinny Buzz 3 (2008 model I think with the shorter straps) and was wondering where I can buy a new one/pair? I also heard you can buy extension straps for the older Quinny models as the current straps are far too short so if anyone knows where you can pick them up would be fab. Thanks!
Hi if you bought buggy in 2007 contact dorel with proof of purchase they will send you new extensions & an xl seat cover. They also can supply the harness pads but you can pick them up cheaper on ebay.
The harness on the Quinny Buzz is sewn into the sub seat and not removable. This means to replace the harness would mean to replace the entire sub seat.
Go to www.quinny.com and select the country you're in, then choose the "Contact Us" tab for your enquiry to go through to the customer care team in your country who can provide more information on how to order and cost.
This is not feedback we've heard before! Remember there are two places to adjust the harness - underneath the shoulder harness pads and at the waist position. To adjust underneath shoulder harness pads you need to undo the popper from the harness, slide the pad down the length of the harness and adjustment point revealed to make harness smaller.
Hi Undo the popper on the shoulder harness pad. Slide the pad down the length of the shoulder harness strap. Unhook the metal D ring. Feed the short length, low down anchor point back in behind the seat fabric. Bring the longer length, higher up anchor point out at the desired height. Re-attach the D ring. Adjust the harness straps accordingly. Slide harness pad back up shoulder harness and re-attach popper.
If it's the new model then you need to follow this in reverse order for Cleaning the Quinny Buzz seats (comfort cushion and XL seat) 1. Open safety harness
2. Unfasten the shoulder belt snap and hook and remove the belt pad. 3. Loosen all snaps on the bottom of the seat
4. Loosen the Velcro straps on the bottom of the seat. Remove the belt buckle through the opening of the seat 5. Slide the cord of the seats out of the edges of the Quinny Buzz seat. Start with the foot section and work towards the head section
6. Pull the lap belt of the Quinny Buzz seat through the holes of the seats and remove the loops from the shoulder belts from the openings of the seat
Hi, to fit the footmuff, you need to undo the straps which can be done right at the top shoulder bit. Once this done you then thread the harness through the side holes on each side of the footmuff, then through the top hole & re-attatch harness to pushchair. All that is left to do it push the **** strap though the bottom of the footmuff. Hope this is of help to you. Regards Marie
If you have the older version Buzz, contact Dorel via their website www.quinny.com and you will be able to get some harness extender straps free of charge. The will come with the instructions on how to attach them.
I would first suggest that you undo the zip on the front of the footmuff. At the top of the stroller shoulder harness, there are pads, underneath the pads you will see a metal hook, undo this to release the straps so that you can then put the footmuff on.
I hope that made sense!
If you unstrap the harness at the shoulder pads, you can then pull the whole strap through sleeping bag and push the bottom part through the hole on the seat, then reclip through shoulder pads.
hey it took me a while to figure it out, at the top of the padded shoulder straps at the back if you feel with your fingers you will find a popper fastening you have to pull it so that it comes away then you should be able to find that the harness is attatched by a loop, take that off and then with the harness unattatched you can thread the slits of the footmuff through and then reattatch it all including the padded shoulder straps, i took mine apart today because my daughter has outgrown the comfort cushion so i took it off after realising there was a bigger seat unit undernath it i bet not alot of people know you can do this, anyhow, by adding the footmuff it makes it alot more padded and cosyier hope that helps!
