Keeping in mind that the soap & bleach gets dispensed into your wash on the
second to last rinse cycle and that most all rinse cycles are in cold
water. Is your cold water valve screen plugged causing your washer to
rinse poorly? Are you using the HE detergent? If not maybe the
washer is sudsing up to much and having a hard time rinsing all the
suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting
does it take a long time to fill the washer up? Also when it is full
and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of
the washer it might have a hard time draining out all of the soap
water before the next load
SOURCE: spinning cycle
usey only takes about 2 tbs soap ather than that bad main board make sure you have cold water going in washer
The machine shows a code of (ie or oe) after washing cycle has completed. How do I clean the drain filter.
Would not spin cleaned filter the machine then did one wash cycle okay then stopped spinning again
