WILL NOT START, OR TURN OVER. I WAS JUST USING IT, MOWING PERFECT, TURN OFF FOR A SECOND
AND NOW IT WILL NOT MAKE A SOUND WHEN I TRY TO START. WHERE ARE THE DEAD MAN SWITCHES LOCATED. THANK'S RON
craftsman LT1000
Most likely the blades are still in the on position,but you have a seat switch, parking brake switch, and the blade switch, also the mow in reverse key switch. if mower dies once you let out the clutch in reverse with blades on and key wrong.
Some have switches to keep you from starting with the cutting blades engaged.
Check fuse and battery connection,do you have your manual?
