SOURCE: lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
SOURCE: jazzy wheelchair 1170....left side stops and sticks,.
those codes 1 light flashing and 2 lights flashing refer to a left and right motor fault respectively....expensive repair
SOURCE: jazzy jet 3
Look in your owners manual for the flash code anwser. Make sure when you hit the power button you only touch it for 1 sec not more. If you press the power button for more the 2-3 seconds you place the power chair in LOCK OUT mode. lights will flash and not power. also check your free wheel levers. one on each moter. Mike
SOURCE: 2 lights blinking on control stick. and chair
sounds like you need a new motor. 2 flashes indicates left motor.
SOURCE: my jazzy 1115 joystick controller flashing and the
look on jazzy web site for lockout procedures.I have seen people accidentally engage the lockout thru the joystick.It is a simple procedure
