I have a 47 in LG 47lc7df. One day trying to turn on the tv the green light blinked a dozen times then turned solid green and there is no picture or sound but the screen looks lit. After trying to turn it on several times it finally works. Now I can't seem to get it to work. What could be the problem and how much would it cost to fix it?
The common problem is the main board, instead to purchase a expensive main board, you may try to re-flow the soldering on the main board, it is the only way you may fix the main board at your home.
Re-Flow Soldering Procedure for LG Main Board
1.Pre-heat your kitchen oven to 385 degree (No more than 400 degree);
2.Put the main board on a card board (like a pizza box board) in the oven;
3.Heat it for 10 minutes (No more than 10 minutes);
4.Turn the oven off & leave the door open, at this moment, do not touch or move the board until it colds down to the room temperature.
5.Install the board in the TV & try it out.
SOURCE: LG 47LC7DF LCD TV turns off with a pop then turns back on.
Sounds like a overheating issue. Try facing a large fan blowing across the back of the unit and see if this changes anything. If it does, it might help to blow the back out with compressed air as dust might be helping it overheat.
SOURCE: LG 47LC7DF Green Light Blinks 16 Times - No Picture or Sound
The lights indicate what the issue is. Kind of like your check engine light in your car tells you something is wrong with the engine.
SOURCE: Problem for LG 47LC7DF 47 in. HDTV LCD Television
television just flashes red and takes at least 15 minutes to turn on after turning off and on and makes a popping sound.
SOURCE: Anyone know where I can
Required T-Con board EAT56804601is available with Shop Jimmy for $50
Click Shop Jimmy link to view board image and price info.
Hope these info will help you.
Thanks.
