Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
Posted on Apr 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ice maker not working
Our kenmore elite bottom freezer ice maker is not working
Anonymous
Level 3:
  • Kenmore Master 43,501 Answers
  • Posted on Sep 30, 2010
Anonymous
Kenmore Master
Level 3:
Answers
43501
Questions
0
Helped
10835305
Points
101584
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
fdfdfs43
5 Related Answers
Anonymous
  • 15935 Answers
  • Posted on Sep 25, 2010
SOURCE: MY ICE MAKER WON'T WORK
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Anonymous
  • 92 Answers
  • Posted on Feb 10, 2008
SOURCE: ice maker not working
make sure its turned on check the wire connector is seated and check to make sure there is nothing jambed in the tray if all that is ok call for service
Anonymous
  • 958 Answers
  • Posted on Sep 30, 2008
SOURCE: kenmore elite - top freezer
if there is ice build up at the back wall of the freezer section, then you have a problem with your defrost cycle. the freezer would not be very cold for the ice maker to work.
it's either your timer, defrost heater or your bi-metal.
tnx 4 using fixya,
drcool
Anonymous
  • 9 Answers
  • Posted on Oct 11, 2008
SOURCE: ICE CUBE MAKER SMELLY ICE CUBES
Unfortunately, this is one of the inherent problems with a self defrosting freezer units. Some frost free models/brands are less smelly than others. Grabbing the cubes as soon as they drop so they don't sit in that nasty freezer air and placing them in a zip lock would help a lot but probably not completely. Be sure and clean the inside of the freezer often so there is less of the smell left in the plastic that surrounds the ice cubes as well as the foods. Don't eat freezer burned vanilla ice cream, for sure! Hope this helps.
Anonymous
  • 103 Answers
  • Posted on Jun 07, 2009
SOURCE: Moldy Ice from Ice Maker
Hi: Does it have a water filter? Sears parts is offline at the moment, so I can't tell. Most of the newer models do. The 596.xxx tells me that it was built in the Amana factory for Kenmore. Most likely there is a water filter in the top of the fresh food compartment. It has been growing mold in storage, and the lines too. It's on the upper right side, behind a housing with a tab to release it. Lower the housing and remove the water filter. Did you receive the bypass plug with the ref.? It looks like a large plastic wing nut with the same fitting as the water filter. If so put it in and flush the system with city water. Most city water has chlorine to clean your lines. If you install a new filter without flushing the lines it will remove the chlorine as it's supposed to do, but the lines from the filter wont get clean. If you don't have the plug, buy one. Flush the system and then install the filter. I hope this helps, Jeff
Our Kenmore Elite (new last summer) bottom freezer double top doors, stopped making ice. The wire that seemingly controls the ice maker is hanging down in a way that is causing difficulty opening the...
Well, that wire is likely the cause of your issue, somebody probably bent it, and now it gets caught on the door or a basket or a food item or what have you, and since it cannot move, the ice maker will not make ice.
I have a Kenmore Elite 59969 and no ice
six weeks old / prob still under factory warranty . but ck the tempts in freezer it must be 15 deg of colder to work . so reset the control for freezer to the highest setting then back one.. this should help .
Icemaker not working on a Kenmore Bottom Freezer
if the volve behind the fridg for the ice get 120v for short time when the ice maker ask for water then the volve is bad but if there is no 120v to the volve then the command not coming from the ice unit and it need to be change , the wholl ice maker unit :(
1helpful
Kenmore elite fridge. Bottom freezer ice builds
You have a bad defrost system on this unit, that's why you're freezing up. Call us with the model number and we'll get the correct part out to you right away. We hope to hear back from you soon.
Kenmore elite bottom freezer icing up
if it has an ice maker fix or adjust the over flow for the ice try.
Ice maker not working but water is new filter elite 75542 40re1451
heatman101
uittu
1helpful
Kenmore elite bottom freezer. Frost, Ice tray
The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
