Televison & Video Logo
Posted on Apr 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Panasonic projection TV does not turn on.
Model PT-52LCX15 fails to turn on. red indicator light flashes 1x /5 sec.
Problem/solution? Thank you.
Steve LaHuis
Level 2:
  • Expert 418 Answers
  • Posted on Apr 18, 2010
Steve LaHuis
Expert
Level 2:
Answers
418
Questions
0
Helped
106415
Points
974
Power LED flashes orange 1 x 5 secs. = 1 of 3 fans stopped. TEMP LED flashes 1 x 5 secs, = Temperature error. Lamp LED flashes 1 x 5 secs. = lamp ballast error. (check lamp 1st.)
Hope this helps.
The model number is PT-52LCX15 power light flashes 5 times the the amber light comes on also the lamp indicator flashes every 5 secongs
You will need to replace the lamp to this unit but with multiple signal lights it may not be your only problem on this. A very common problem is the power supply on these as well.
PT-52LCX15 when you turn on the tv the lamp comes on for about 2 seconds and it turns off then the power light blinks 5 times then the yellow
If you google how many times the light flashes with the t.v model that should tell you what your problem is.
Might be your bulb.
Panasonic multimedia projection HDGT tv color spots displayed
PANASONIC..PT-52LCX15. STARTED TO A LIGHT COMES ON THE SCREEN. THEN TWO LIGHTS. FINALLY TV DONT COMES ON. I PUT ON THE TV, AND ON BOTTON START BLINKING AND TV DONT COME ON..I TAKE OUT THE TV LAMP..IT LOOKS GOOD NOT BURN. SHOULD I REPLACE IT??
My tv does not come on and the red light inthe front flashes 3 ti
The 3 blink error code is indicating that the Convergence ICs have failed. You can get the repair kit for your model which contains both convergence IC and the six feed resistors and it also has step by step instructions with pictures that show how to do the repair. Heres a link to the repair kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
4helpful
Red led light flashes 6 times and tv won't turn on
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code refers to an power set up problem,see incoming voltage with an multimeter.......
thank u,,,,,,,,
Panasonic PT-53TWD63, TV will not turn on, Red power light blinks
It is most deffinately a convergence chip issue. The die for no reason. They can be bought online for around $10 dollars and anyone with experience with soldering can replace them pretty easily. I have done it.
6helpful
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
