Sounds like one of the motors might be bad, you can get a new motor and tires here www.powerwheelsoutlet.com
SOURCE: Peg Perego John Deere tractor 12volt will only
check all wre connections are not dirty or loose!
lift out pedal swith to check there too!
Cheeers Rob
SOURCE: We bought a Peg Perego john deere hpx. where can
You could try here. http://tigerimports.net/sunshop/
SOURCE: We just replaced the battery and it worked fine
Use a meter to confirm whether the battery is still working. The meter should read around 12-13 VDC if the battery is good. The 12 Volt Peg Perego battery is made with 2 6 volt batteries connected in series. Maybe the connection broke when the battery fell out. Check the connection and also check with a meter if either battery is pumping out 6 volts.
SOURCE: where and how do I
hi, open the hood. disconnect the battery and connect the charger and leave it 8-12 hours. if you dont have a charger, ebay is the best place to pick one up cheap!
good luck!
