Kenmore Elite HE5t Washer Logo
Posted on Apr 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error f35? What's the fix?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1036
Points
SUDS might arise out of adding too much detergent.
Power off, remove clothes from the machine, see if the machine operates on Spin and Drain. Then try a Rinse and Drain cycle with no clothes.
If all fine, put some of the clothes back and try normal wash cycle.
Anonymous
Level 1:
New Friend:
  • Posted on May 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1036
Points
They can and fixed my washer today! The fix was the replacement of a switch. The item # was W10156252 for my washer. It is called a switch-WL. Item # may be different for your model. I was getting SUDS and F35 errors. To install it you just remove the top part of the washer and should be located at the upper right-hand side, attached to a black hose. The switch has a small computer board. The price of the swith is around $130. Fortunately I bought a 3-year warranty on my washer.
Anonymous
Level 3:
  • Master 11,896 Answers
  • Posted on Apr 18, 2010
Anonymous
Master
Level 3:
Answers
11896
Questions
Helped
3734613
Points
36074
This is a suds overdoes error. Meaning it detects to many suds in the machine. Try using a rinse cycle to water down those suds. Then a normal cycle without adding any more detergent. This should fix the problem
1helpful
What does error F35 mean?
It helps to have FULL make and model in such questions, but here are a few ideas
The F35 error code indicates an analog pressure sensor error. The analog pressure sensor is the component that detects water level in the washer tub. This error can usually be cleared but it will occur again if the main control board still detects a problem with the signal from the analog pressure sensor.
Jun 4, 2011
F35 error code appears during cycle - iFixit
https://www.ifixit.com > Answers > View > F35+error+co...
About
Whirlpool duet washer f35 error code
https://all-errors.com > whirlpool-duet-washer-f35-error
The F35 error code in the Whirlpool washer indicates some problems with the water level pressure switch. This sensor is responsible for measuring the amount ...
Troubleshooting the F35 Sud Error Code in the Whirlpool Duet ...
https://www.youtube.com > watch
PREVIEW
12:49 Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam Washer · For more tech advice on ...
YouTube · SamuraiRepairman · Oct 5, 2013
1helpful
2answers
F35 ERROR IN DIAGNOSTIC TEST C:00 I have been getting the same F35/Suds error as previous posters. When I enter the diagnostic test only, I can successfully get through all diagnostics. The first time. ...
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
1helpful
Code F35
hello
what The F35 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
The f35 error shows you and indication that ice maker sensor readings are out of normal range.
then what you need to do to fix up the problem is to bale out the water from it then clean up all form of water ant dry you can see from the screen
Please before you can carry out this instruction you will have to put OFF all source of power supply .
thank you and good luck.
4helpful
2answers
What does f35 mean
Hello there
F35 found in this link
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
F35 means ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
1helpful
3answers
F35 message, will not run through cycle. Starts to and then the F35 starts flashing and eventually shuts off.
Check between door boot seal and drain hose in basket. If this is clogged with lint or sock, towel it will code f35 or sud
2helpful
WASHER WILL NOT RUN. COMES UP WITH F35 ERROR AND
analog pressure sensor failure 1 check if the pressure hose is fixed correctly 2 check the air trap is not blocked 3 check if the hose is not blocked good luck
shaun
1helpful
2answers
F35 and suds it turns off after 5 mins and whenever I put it on rince only it still cuts off.
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
2helpful
5answers
Whirlpool Duet Steam washer
HELLO.F35 IS A ERROR CODE WHICH NEEDS THE ASSISTANCE OF A WHILPOOL SERVICE AGENT.THE CONTROL BOARD MIGHT NEED TO BE REPROGRAMED BEFOR YOU CONSIDER REPLACING IT.GOODLUCK.MOHAMED
5helpful
2answers
Error code f35
konica f 35 eror code
Alexander
vince
