TV will not remember settings. At startup tv always asked to run channel search even if I've manually programmed favorites and blocked all others. Other settings such as power save mode also reset to defaults.
Probably you are in "shop" mode of TV. Try to reset your TV and go through initial setup. Most important - choose "home" instead of "shop" when asked during initial setup. Resetting - keep up arrow pressed and switch of TV. Keep the button pressed when TV automatically switch back on. This will reset TV to factory defaults.
Hi my tv is locked into channel 44 and wont change
