WATER IS COLLECTING UNDER VEGGIE BINS/ CLEANED COILS & DRAIN ....WAS MANUFACTURED 08/99
MODEL ....ET216KXHWOO
SERIAL.....EJ3334545
TYPE......CZ1TFA99
Sounds like you do have a clogged drain tube, its self defrosting but the defrost water is pooling under hte crispers instead of in the drain pan under unit.so you ll either have to remove hte rear panel of freezer and locate the drain trough/ tube, and defrost it allowing for water to drain down, o rclear all the tube leading down to the drain pan.
Yes, I have the same Problem. I'm worried about taking off the back pane vis a vis electrical connections.
