I have to refplace the scanner on my fax machine but can't figure out how to remove the old and put in the new. Please help
First remove the scanner control panel. pry the hinges out slightly and you can take off the control panel, then there are 4 or 5 screws and the top comes off. The 2 long rollers come out too. move the clip and slide them to the right. The scanner is the 3/4 inch wide 8 inch long scanner. ( the glass that reads your faxes to send ) It is coonected with a flat cable. It pops up when you push the clips holding it down. Lawrence
Be sure to lightly pull the are, move the CIS(scanner) to the right and lift up the lift edge of the CIS unit gently. Do not lift the left edge exceeding 30 mm to prevent the CIS harness connector on the CIS unit from getting broken.
While holding the CIS unit, disconnect the CIS harness. The CIS spring comes off also.
3 FPC key
4 LCD
5 Scanner Frame Assembly
6 Document feed roller assembly
7 Document ejection roller assembly
8 Pinch rollers
9 CIS unit (scanner)
When reinstalling the CIS unit, first connect the CIS harness, insert the right end under the arm of the scanner frame, put the CIS unit into the scanner frame, and then move it to the left.
