Chain/bar oiler tube loose in tank. How do I reattach?
Check the loose end of the line--does it look rotted, or does it have a clean cut end? If rotted, and there is a plastic stub in the tank, replace the line--remove the remaining piece of line from the stub. Use extra-long 'hemostat' clamps (available from Harbor Freight tools) to work the tube onto the stub. If the old tube appears to go straight through the tank wall, then you will have to remove the outer case to replace the entire line to the pump.
