SOURCE: can not remove axle cover,
Hi, easy fix you have to pry the cover off. you can use a screw driver, or a pry bar.
SOURCE: 20 Year Old Craftsman Lawn Tractor Steering Gear Slips
check top of sector gear mounting plate for waer this is the gear that hooks to you steering gear . the plate that it mounts to will ware down causing it to be loos and slip . the only way i know to fix it is to pull the cross member out and take it to a welding shop and have it built back up.if the bolt is as tight as itcan go .
SOURCE: replace drive belt Craftsman 917-255572
First you have to remove the deck,then you may have to remove belt guards to install new one,then reinstall the deck
SOURCE: how do i replace the lift shaft assembly on my
there is not enough space here to describe the replacement procedure. some helpful tips though - order the part you are replacing [ordering from sears tell them: division 71, source 917, part no. 159471] before you tear into it. sitting around for 3 or 4 weeks, you'll probably forget where things attach. also, find the exploded parts diagram in your owner's manual and look it over carefully to see what you're getting yourself into. sometimes, it's worth a few bucks to let a competent shop do the work
SOURCE: Model # 917256563 19.5 hp
If the tractor stopped abrubtly, you may have bent something pertaining to the frame or the clutch pedal assembly if you caught your weight on the clutch when it stopped. Sears parts.com has en exploded view if you enter your model number
