Hi Ron,
Having at one time done warranty service on those machines in a decent size city ( Calgary Ab. Canada ), I saw these almost daily so I know exactly what is preventing the clothes from drying ( 99% sure at least )...even though as you`ve stated "feel heat around the machine". The condensor fan wheel and heater housing are clogged with lint.
**turn off the power or unplug the "combo" from the wall**
If you are capable of removing the top you'll soon notice there is not much elbow room in there to work...even less than home units which are a little easier, but not much. Fortunately for this issue you won't need much. On top, directly behind the timer on the right hand side top of the tub, is a "condensor/heater housing" ( usually made of "white metal" or "pot metal" as some refer to it ) with a blower fan motor fastened to the top. Remove the fan motor wires and then the motor itself from the housing via four hex head screws ( they may be philips heads...that`s not important ) around the perimeter of the fan motor bracket.
This is where "elbow room" may be tight, but with persistence and careful maneuvering you can do it. You may be able to move the tub to the back and left While backing out the fastener's/screws to give you a little more room. Pull the motor assembly up & out ( careful of wires and sharp edges ) and examine the blower wheel and housing. By now it should be obvious of the problem. These unit's because they are so compact are vulnerable to lint build up in the blower wheel and housing hence, the unit will not perform well in the "dry" cycle.
When you have the blower removed I find running hot water from the sink tap ( or anywhere...I don't think it matters, ha ha ! ) over the blower wheel cleans it thoroughly. Cleaning out the condensor housing is a nother matter...by hand is one way to do it. It can be cleaned via a garden house, but be careful not to overfill the tub or flood your place. ( if possible, take the washer right out of the RV/motor home ) Normally it drains when plugged in, but since your's is not plugged in it will have to drain with gravity, that`s why it`s good to remove the entire machine from indoors.
Hope that helps move you forward, or better yet solves the problem entirely.
Let me know if I can assist you further, I'll watch for your reply here.
Thank's for visiting "fixya" for your repair inquiries.
Good luck,
Macmarkus :)
Hello again,
All this may be correct, but I should have asked if the clothes are spun out before the dry cycle begins, or are they soaking wet ?
There may be a problem with the motor brushes if they aren`t spun out well.
I`ll watch for your reply Ron.
macmarkus :)
I have had same issue however there is no lint and nothing looks amiss with blower or motor.. no buildup. any other suggestions? Barbara V
