My refridgerator makes a loud humming sound when it "kicks on" and will continue to make this sound until it "kicks off". Any ideas as to what it is and how to fix...compressor or somthing else??
The noise my be do to vibration. Is there any spot on the dishwasher where you can put your hand to temporary stop the noise do to vibration? I’ll continue my answer after your feedback.
Hello, your refridgerator in most likely in defrost cycle. the noise your hearing is the water dripping on the hot heater and ice dropping off the evaporator. should only last 15 minutes and then your all set. Mike
humming sound is your magneto going out Dont have any idea of the cost for replacement however it may be cheaper to purchase another microwave than to repair this one. Good Luck
You need to clean your coils under the 'fridge,' and wait 24 hours, if it is not not getting cold, perhaps replace the freon. If that does not work, you need to call a repairman.
I am looking up your refrigerator to see the right parts. Sounds like the defrost cycle is not happening. look for a defrost or adaptive defrost board. Check your model number again because I am not able to find the number listed. I will continue to check for the correct refrigerator and if you find a simple defost timer turn it clockwise slowly until you feel and hear a click. If you do and you may hear the elements heat up inside the freezer. If that happens just put a new defrost timer and you should be set. Sea Breeze
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa Michael Anderson Anderson Appliance (865)945-3808
When the heat is not on. Go to the T-stat and turn the fan to the on position. With the blower now running is it making the noise? If so you probably either have something in there such as the filter that was mentioned, a piece of paper etc. or one or more of the blades on the blower wheel is vibrating. Don't let the condition persist w/o having it checked out or you may turn a simple fix into a costly one.
