Question about GE WDSR2080D Top Load Washer
Filling problem the water will not go into tub. the plumbing is ok its the part that hooks up to plumbing. what is this piece and can it be repaired. all other cycles work fine
    Top Expert:
  • GE Master
  • 6,289 Answers
Yep most likely the water valve
Posted on Dec 10, 2018
    Habit-Forming:
    New Friend:
  • 141 Answers
You might try calling a professional plumber to come to take a look at your washer. The plumber would know if something were bad and how to properly fix it. That is what I would want to do so that I wouldn't have to worry about diagnosing the problem myself. https://www.plumbitinc.com/sump-pump-installation-n-repair
  • GE Master
  • 43,501 Answers
The soleniod valve is bad.... here is a tip that will help...
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
Posted on Apr 12, 2010
Anonymous
SOURCE:
Broke the plastic screen that goes to the cold water inlet valve?
The broken bit of filter has probably got stuck under the rubber diaphragm in the inlet valve. You will have to strip the inlet valve and remove the piece. There should be 3 or 4 screws holding the valve together. Make a note of how it comes apart. There will be a spring, a metal plunger and the rubber diaphragm inside the valve.
Apr 27, 2017 | Maytag Washing Machines
Hot water stops flowing intermittently from tub faucet
Newer tub faucets have a anti-scald feature. It normally looks like a piece of plastic dial just above or below The tub handle. It could be that your water set too hott and he scald valve shuts off the hot water only
Sep 04, 2017 | Plumbing
Will not run cycle when clothes are in machine
RUSTIN...RUSTIN...RUSTIN! I presume water is still in the Tub? Thought so...OK "IF" your Drain Filter, hose, and house plumbing are Clear...(Are They?) then it is your Drain Pump. Circuit Boards rarely go out and unless you are cutting wires, they don't fail either. A pump will, it either works...pumps OUT the water OR it doesn't. If it doesn't then the tub fills with water, STOPS, and goes on Strike! No it will not spin cause your machine would end up on the sidewalk thumping and clankin all the way! Change the Drain Pump. UN-PLUG DA MACHINE FIRST!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Sep 11, 2013 | LG WM2688HWM TROMM SteamWasher
I recently found that my washer is causing a leak, only on the first drain cycle. The second drain cycle is fine. I thought I had a plumbing problem with the drain, however after snaking it and using ...
The most common leak point for this machine is at the center tub seal. Remove the front panel by removing the screws from the bottom of the front panel. Look at the bottom of the tub, directly in the center. See if there are any water marks around this seal or around the inside of the cabinet. If there is, this is a pretty intense repair requiring specialty tools, so you will likely need to call in a servicer. This typically runs about $300 or more to repair.
Jan 13, 2011 | Maytag LSE7806A Top Load Stacked...
Water coming out of hose at home plumbing
Hello.Maybe the drain is blocked.it sounds like your machine is working ok to me,if you can hang the hose over the edge of a laundry tub & make sure the plug is out,see if the water drains away,otherwise it sounds like a plumbing problem not the machine.it started only after you moved houses so more likely the plumbing.hope i helped.
May 28, 2010 | Maytag HAV2557 Top Load Washer
Water overflow when tub is emptying during spin cycle
It sounds more like you have a drain problem that a machine problem. Try draining into the laundry tub and check that the tub drains quickly enough. If not, you have a plumbing problem...Good luck...Nomess
May 14, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washer leaking water out bottom in rinse or spin cycle.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Jan 24, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Washer Water Leak
Pump is not repairable and yes your pump is shot. You can replace it farely easily and cheap at repairclinic.com
May 22, 2009 | Washing Machines
GE WDSR2080D Top Load Washer Logo
73 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
