When i push the up or down channel buttons, the input is changed instead. I can still change the input through the menu route, and I can still change the channel by typing in the channel number and pressing enter (eg. number 3 enter goes to 3). Also, the up and down channel buttons change the input whether using those on the tv itself or those on the remote. I tried using reset as well, to no avail... please help. Thanks in advance
SOURCE: My TV has sound but No image!!!
a 42hp66 is a plasma set,, the y-sus or the z-sus circuit board has probably gone bad.. as these are expensive parts you might want to have a technician determine which one of the two is bad before ordering both of them
SOURCE: Toshiba 50HP66--can't change channels anymore
I had this problem. Unplug it while it is powered on. Worked for me.
SOURCE: I want to set the remote to change volume on TV
I am not familiar with the Time Warner remote, but Tivo remotes require pressing "tv power" and the "Tivo" button at the same time to program them.
Maybe you are pressing one a little ahead of the other.
SOURCE: when I turn on the tv, Get a blank screen with
Unplug it,replug it back an hour later,the tv should set back to the factory setting.
I have the same problem now, did you find a solution?
