Sde5401ayw dryer may run a moment on air fluff. any heat cycle trips circuit (30amp) breaker immediately. breaker replaced, no change. running again on air fluff after sitting a while.
Is the dryer gas or electric? Does it plug into a 110Volt outlet or a 220Volt outlet? Does it trip the circuit breaker immediately or will it run for a while and then trip the breaker? If it is tripping immediately then there is a short inside the unit. If it takes a while to trip the breaker it can be that the outlet you are using is not a dedicated line and has other circuits connected to it. If that's the case you are overloading the breaker and causing it to shut down. If it is a dedicated line that you are plugged into then something inside the unit is heating up when its in use and overloading the circuit breaker. Then the unit needs service.
First, see if you get the same result when you run the machine on "Air-Fluff." If you don't pop the breaker on Air -Fluff you know the problem is originating in the heat circuit, get inside the machine and inspect the wiring for crispy/burned terminals and the heat element for damage or contact with the housing... If it does pop the breaker on Air-Fluff: Inspect the terminal block on the back of the unit where the power cord is bolted on (with the unit unplugged), look for any scorched spots- if that is clear, remove the outlet cover and inspect the wire connections on it for scorching (with the circuit break off). Can't be more specific without a model #! Help Me Find My Model Number RepairClinic com
First check the load and grounding, you will need to measure the amperage draw wih an ammerter, also check to see if it trips when a large unit like a motor or air conditioner starts, it may not be able to handle the inrush. Also be aware that if your breaker is a 30amp does not mean you can pull 30amp you can safely constantly draw 80% of that. Also check your grounding of the equipment you are powering.
There are several ways. One way is to turn your dryer to air fluff or no heat and see if it trips the breaker. Another way is to physically examine the element. Unplug the dryer before attempting to service. If this does not cure your problem please comment me so I can assist further.
The circuit breaker may be tripping because of a fault with the dryer or it may be a fault with the circuit breaker being weak.
From the description you give the circuit breakers trip frequently.
I'd suggest you first try selecting the no heat air fluff cycle and run it to see if the breaker trips. If the circuit breaker doesn't trip in air fluff then there is likely a short in the heating element.
With a clamp-on amp meter you can read the amp draw of the dryer when it is heating. With the motor and element both working you would see approximately 25-26 amperes being drawn. The breaker is rated at 30 amps. If the breaker trips and only 26 amps are being drawn then the breaker is the problem.
Try the air fluff cycle first and see if the breaker will trip. Then with additional details I may be able to help you further.
First clean the vent in the machine and the wall. Try the machine one time not connected to the wall, see if it works better. Carefully tighten the wire connections at the breaker, including the white. It is possible for a breaker to get weak. Your motor may be wearing out.
If your circuit breaker(s) are tripping as soon as you turn on the dryer you have a dead short. Try the dryer set on fluff (or no heat). If it runs OK then, short is most likely in the heating element.
The problem may not be with your dryer but with the circuit breaker...
Locate the circuit breaker for the dryer. Run the dryer for awhile and with the back of your finger pressed against each of the two switches (it will be a double breaker), see if the breaker is getting warm or wait until the dryer quits then check the breaker for any noticeable increase in temperature. With properly rated breakers, they should not get warm. If getting warm, it is a sign the breaker is bad and should be replaced.
