Check:
- is gasoline in the tank?
- is there a spark emitted at the spark plug if held to the cylinder while cranking the engine.
- is the headlight lighting up while cranking?
use a starter-spray in the air intake
Vespa 150GS VS5 spark check
SOURCE: Piaggio Vespa ET2 Scooter slows down when eccelerating
my does the same do you no what the problem is because i need to find what it is and fix it.......
SOURCE: Vespa Scooter: puting brand new wheel and tyres together ,vespa 3...
Semi inflate the inner tube a little as this helps prevent it getting nipped between the two sides of the wheel on assembly. And a bit of grease on the wheel halves helps the tyre to slide into the bead better.
Or do what I and a lot of scooterists are doing..............scrapping the old half & half steel wheels and replacing them with alloy tubeless ones from SIP Scooters. Available in polished alloy or matt black with polished rim. They look good, don't rust and are lighter but the real improvement is that they are far less prone to blow-outs, punctures and rapid deflation all of which increase the safety tenfold. They cost around £50 - £60 each but you can't put a price on safety.
SOURCE: i hava a vespa vbb
The whistling is caused by the main wheel shaft bearing - it's severely worn out and the seal is gone. You will have to replace it as soon as possible - the scooter is not safe to run in this condition.
