We are replacing our stove top with one that is just a bit smaller (Frigidaire FEC30C4AS1) . You can see through to the cabinet below on the sides of the stovetop and it barely catches on the front and back sides. Is there some sort of mounting ring that can fix this problem? Otherwise, we will need to buy a larger stove top or replace the counter.
SOURCE: Replacement of glass top
Unplug first! Find the screws that hold the cooktop to the range. Usually in the front just above the oven door when it is closed on the underside. This should release the cooktop. The burners and wiring may have to be removed. You can order the part at sears.com.
SOURCE: changing the surface burner spark electrode for GE stovetop
Schematic -
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=JGP326WEV1WW&productCategoryId=0121050&brandId=0432&modelName=GAS-COOKTOP&diagramPageId=00001&componentDescription=COOKTOP&documentId=10053061&backToLink=Return%20to%20Sub%20Components%20list
SOURCE: Counter top stove burner won't light
Hi, You asked a very generic question but I will try to give you a good answer. If the pilot is good and you can light the burner with a match, (this checks everything else) then the most common problem would be the burner holes in front of the pilot are clogged. When cool, remove the burner and inspect the holes, any debris needs to be removed, a bent paper clip works really well. Compressed air helps as well. If there is a tube to the pilot make sure it is exactly where it belongs and that it is clean. If the match didn't light the burner or the flames is not all blue like the rest, there is something else wrong and you need to get back to us with a make and model to better help you. Make sure the burner gets seated back on the orifice correctly and best of Luck to you!
Hey Tamara webber, thanks for your inquiry!
I see that you would like to remove the control panel on your Frigidaire range, CFES367DC2. . Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree and please do not hesitate to reconnect. -Matt
Hey friend, thanks for your post!
I understand that you want instructions on how to remove the main cooktop on your Frigidaire range, FFGF3047LSE. Some of these parts require precision and patience when replacing the exchange of such components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Matt
