Question about Sharp XE-A402 Electronic Cash Register
My digital touch pad sharp cash register ER-A550S just not working at all All it shows is this sign -------- please help. when i push any key, does not type or show anything. just bip noise but nothing showing, just show this ----------- I switched of the plug so many times, turned back on straight away just show --------- and thats all it appears on the screen
This is common. You have a printer jam. Look for paper stuck in the mechanism - especially under the front plate.
All of these manuals can be downloaded at:
http://the-checkout-tech.com/
sharp ER-1017 Service
sharp ER-1072 Service
sharp ER-1073 Service
sharp ER-1074 Service
sharp ER-1075 Service
sharp ER-1076 User Service
sharp ER-1077 Service Programming
sharp ER-1077
sharp ER-1077
sharp ER-1772 Service
sharp ER-1772s Service
sharp ER-1871 Service
sharp ER-1872 Service
sharp ER-1873 User Service
sharp ER-1875 User Service
sharp ER-1910 User Service
sharp ER-1911 User Service Programming
sharp ER-1911s User Programming
sharp ER-1920 User Service
sharp ER-1921 User(R) Service Programming
sharp ER-1921s Programming
sharp ER-1970 User Service Programming
sharp ER-2000U Service
sharp ER-2100 User Service
sharp ER-2370 Service
sharp ER-2371 User(R) Service Programming(R)
sharp ER-2385 Service
sharp ER-2386 Service
sharp ER-2386s User
sharp ER-2395 Service
sharp ER-2396 Service
sharp ER-2720 Service
sharp ER-2722 Service
sharp ER-2722A User Service
sharp ER-2742 Service
sharp ER-2742A Service
sharp ER-2770 Service
sharp ER-2782 Service
sharp ER-2782A Service
sharp ER-2905 Service
sharp ER-2908 Service
sharp ER-2910 Service Programming
sharp ER-2970 User Service
sharp ER-2975 Service
sharp ER-2980 User Service
sharp ER-2980S Service
sharp ER-3100 User Service Programming
sharp ER-3110 User Service Programming
sharp ER-3115 Service Programming
sharp ER-3120 User Service Programming
sharp ER-3550 Service
sharp ER-3600 User Service
sharp ER-3630 User Service
sharp ER-3712 User Service
sharp ER-3721 Service
sharp ER-3731 Service
sharp ER-3732 User Service
sharp ER-4100 User Service Programming(R)
sharp ER-4110 User Service Programming(R)
sharp ER-4100S Service
sharp ER-4110S Service
sharp ER-4550 Service
sharp ER-4630 User Service
sharp ER-4633 Service
sharp ER-4700 User
sharp ER-6740 Service
sharp ER-8700 Not Available, do you want to swap?
sharp ER-A150 User Service Programming
sharp ER-A160 User Service Programming
sharp ER-A170 User(R) Service Programming
sharp ER-A180 User Service Programming
sharp ER-A220 User Service Programming
sharp ER-A227G Programming
sharp ER-A250 User Service Programming
sharp ER-A310 User Service Programming
sharp ER-A320 User Programming
sharp ER-A330 User Service Programming
sharp ER-A410 User Service Programming
sharp ER-A420 User Service Programming
sharp ER-A430 User Service Programming
sharp ER-A440 User Service Programming
sharp ER-A440S Programming
sharp ER-A450 User Programming
sharp ER-A450S User Service Programming
sharp ER-A450T User Service Programming
sharp ER-A460 User Service Programming
sharp ER-A470 User Service Programming
sharp ER-A490 User(R) Service Programming
sharp ER-A510 User Service Programming
sharp ER-A510s Service
sharp ER-A520 User Service Programming
sharp ER-A530 User Service Programming
sharp ER-A550 User Service Programming
sharp ER-A550s User(R) Service
sharp ER-A570 User Service Programming
sharp ER-A610 User Service Programming
sharp ER-A650 User Service Programming
sharp ER-A650S Programming
sharp ER-A670 Not Available, do you want to swap?
sharp ER-A670S Programming
sharp ER-A750 User Service Programming
sharp ER-A770 User Service Programming
sharp ER-A770II User
sharp ER-A770M User Service
sharp ER-A771 User Service Programming
sharp ER-A850 User
sharp ER-A880 Not Available, do you want to swap?
sharp UP-3300 User Service Programming
sharp UP-3300M Service
sharp UP-3301 User Service Programming
sharp UP-600 User Service Programming
sharp UP-700 User Service Programming
sharp UP-800F User
sharp UP-810F User
sharp UP-820N User Service
sharp UP-X300 User
sharp UP-X500 User Service
sharp XE-A101 User Service Programming
sharp XE-A102 User Programming
sharp XE-A106 User
sharp XE-A110 User Service Programming
sharp XE-A120 User Service Programming
sharp XE-A130 User Service Programming
sharp XE-A201 User Service Programming
sharp XE-A202 User Service Programming
sharp XE-A203 User Programming
sharp XE-A206 User
sharp XE-A20S User Programming
sharp XE-A212 User Service Programming
sharp XE-A213 User Programming
sharp XE-A301 User Service Programming
sharp XE-A302 User Programming
sharp XE-A303 ? Programming
sharp XE-A401 User Programming
sharp XE-A402 User
sharp XE-A406 User
sharp XE-A40S User Programming
sharp XE-A505 User Programming
Posted on Jun 06, 2010
Does it beep on and off repeatedly until you power-off? I believe it's a Motor Lock. The register receives timing pulses back from the printer whenever the motor is running; if those timing pulses don't come back fast enough, it stops trying to run the motor to prevent burning things up.
It might need a new motor, but it could be something cheap and simple. occasionally a ribbon gets jammed inside the cartridge & stalls the printer. Remove the ribbon cartridge and try turning the knob on it by hand. It should be stiff, but not jammed completely.
More likely, the rod that the printhead carrier slides back and forth on is cruddy with old oil & dust. Remove the ribbon. Raise the black paper-feed section. (Release it by pulling on the two levers on top.) Two screws hold the metal plate that covers the printhead. Remove them and rotate it up to release the hooks that hold the front down. Use a rag with just a few drops of very light oil (My favorite is Marvel Mystery Oil.) to wipe the rod clean.
Plug the power back in and hold a paper feed button down to see if it runs smoothly. Unplug again. If it seems OK, put it back together, including ribbon & paper, apply power, and touch the CL key before anything else. That should release it from the Motor Lock condition. It will finish printing whatever it was doing before.
If cleaning the rail doesn't fix it, look at the 1.5-inch diameter, black disk low on the printer's right rear. The slots on the disk are read optically to produce those timing pulse. If it's clogged with dust, the register may think the printer is stalled. Fix that by brushing it gently. The disk runs through a slot in the optical reader; I use a pipe cleaner to clean the slot.
Posted on Apr 21, 2010
My Sharp Er-2386S has frozen with the "Not Assigned" on the display screen.
I have tryed to Clear the machine
I have tryed to unplug to reboot
Posted on Oct 21, 2012
Jan 09, 2017 | Sharp ER-A440 Cash Register
Jan 19, 2015 | Sharp Er-a550s Cash System Cash Register...
Mar 25, 2014 | Sharp ER-A450S Cash Register
Nov 26, 2013 | Sharp XE-A402 Electronic Cash Register
Sep 10, 2013 | Sharp Er-a550s Cash System Cash Register...
Oct 25, 2012 | Sharp Er-a550s Cash System Cash Register...
Oct 23, 2012 | Sharp ER-A330 Cash Register
Oct 16, 2012 | Sharp XE-A402 Electronic Cash Register
Dec 30, 2009 | Sharp XE-A402 Electronic Cash Register
8,053 people viewed this question
The sam4s register is on but the amount light screen isnt showing what do i need to do?
the amount screen isnt working not showing anything what do i do?
I have just got a second hand ER-290 cash register and can not open the till. Please help
hello i got Sharp ER 2396 cash register and it stop working any button i press it it gives me E error on left corner sound can you help me please
