HP Master
- Posted on Apr 10, 2010
Re: i want to install printer hp deskjet d2460
How to install Printer
Follow these steps to install the downloaded software.
When the download is complete and you are ready to install the files, click Open Folder , and then click the downloaded file. The file name ends in .exe .
NOTE:
If you closed the Download Complete screen, browse to the folder where you saved the .exe file, and then click it.
You can accept the default place to save the files. Click Next , and then wait while the installer extracts the files to prepare for installation.
When the Install Wizard starts, follow the on-screen instructions to install the software.
NOTE:
If you have previously installed the software and are changing the connection type from USB to Ethernet, click Add a device when the Uninstall the software or Add a device window opens.
For a Full Feature installation, you choose what type of installation you want. The following information might help you decide which installation type to use.
Typical (Recommended)
Minimum
For full use of all your product features : HP includes valuable software to help you get the most out of your product.
HP designed this installation type to work for most users.
A custom type of installation might be available for your product. This installation allows you to install the minimum software required or the preferred software. Use this type of installation only if you have one of the following reasons:
The computer is low on hard disk space.
You attempted a recommended type of installation and received errors. (If errors occur during the recommended installation, fix them before trying a custom installation.)
NOTE:
NOTE:
Minimum
