Noise in the phone line, or low signal strength during fax transmission can result in fax failures. Noise or poor signal strength can cause a partial or complete loss of fax information during transmission. When Error Correction Mode (ECM) is on, the receiving fax machine checks the fax information for errors during reception. If the receiving fax machine detects an error, the receiving fax requests that the sending fax resend the information. Resending all or part of the information can make transmission times longer, but helps improve the quality of the received fax.
If the phone line quality or signal strength is extremely poor, sending a fax can fail. Turning off ECM can improve the ability of the product to send a fax successfully when the phone line quality is poor. However, the image quality of the received fax might be poor.
If ECM must be off to send faxes successfully, have the telephone service provider check the phone line quality. For an HP Fax, turning off ECM from the control panel does not necessarily mean that fax transmission will not use ECM. Fax products use ECM as follows.
All faxes sent in color use ECM.
All faxes sent at the highest transmission speed use ECM.
The ECM setting affects only sent faxes, not received faxes.
Enabling or disabling Error correction mode (ECM)
On the product control panel, press the Menu button ( ).
- Use the arrow buttons ( ) to select Basic Fax , and then press the OK button ( ).
- Use the arrow buttons ( ) to select ECM Mode , and then press the OK button ( ).
- Use the arrow buttons ( ) to select On or Off , and then press the OK button ( ) to confirm the setting.
- Press the Back button ( ) twice to return to the main screen.
we have the same problem. its not the other fax as ive experimented with sending from other internal fax machines. comes out fine on other fax machine, but not this one. this also never happened before, we've been using this machine a few years and it is a new problem.
