My sony ericsson is not supporting java.when i try to download a java file it shows "insufficient memory" or "operation failed".My application and games memory status have become 0 bytes.when i click on these nothing happens like they are not responding. please provide me a solution to solve the problem.
First, you need to download the PC Suite for your phone. Next, you need to update your phone's software. (Note: you will need a USB- data cable specifically made for your phone if you don't already have one.)
Requirements
Then,click on this website:
Sony Ericsson W550i Support
And, download both of these programs on your PC.
Install the PC Suite first. Then run the phone's update program.
Java is installed from the factory and cannot be repaired when it stops working properly - unless you install an update program to the phone.
Take your time, be patient and follow all of the instructions exactly.
The update program may wipe all of your applications off your phone, so use the PC Suite to make a back-up of your files before you begin to update your phone.
You'll have your phone operating as good as new in no time at all.
Anyway to view PDF files you have to download PDF Reader (Download links given below) or send it to your Sony Ericson and install the application.As far as I know this PDF reader supports the following Models
Sony Ericsson k750i
Sony Ericsson W810i
Sony Ericsson k800
Sony Ericsson p990
Sometimes you might get a "Invalid Application" or "Operation Failed" error, in that case try to re install PDF reader application! As Sony Ericsson mobile phones support .Jar file extension,I have uploaded the PDF Jar file to different file hosting!
check this lick for SONY mobile softwares.--http://ptf.com/sony/sony+ericsson+c902+mobil+software+pdf+reader+java+free+downlod/
thanks for rating
Good luck
