Under the bottom hinge, unbolt it, remove plastic plugs on other side of door, transfer hinges over and door handle, refit the lower one in new position, put plastic plugs in old holes
Try unplugging the freezer and leave the door open for about 30 to 45 minutes. Don't forget the door is open and plug the freezer back in. Set a timer in the kitchen so you don't forget. Once you can open the drawers look inside the freezer sides to find the controller. Most models have turn dial inside.
Good day,
A lot of people create problems trying to rush a defrost. Using heat or utensils can create problems and even do serious damage.
My advice to you is to unplug the machine, empty the machine and use a large fan directed into the interior of the machine. It will take some time but will keep you out of trouble.
As well, when restarting, load all the food plug it in and stay out of it for at least 6 hours. Opening the doors frequently to see how it is doing will just slow the cooling process down, since warm air enters it every time you do a door opening.
loud buzzing I believe is an alarm that is waring you that the freezer is not cold enough. Door problems can be fixed. Test is to stick a dollar bill in the door and shut it. It should be a little hard to pull the bill out. Do this all over the door and find all the bad places. One problem is that the door can become warped by banging it against something or kids hanging on it etc. If you can see the warp you can actually bend the door back into place by holding the bottom of the door and moving the top in the necessary direction. Like jamming your foot against the bottom and pulling on the top or putting a box at the bottom of the door to hold it open and push the top. Next many time the bad fit door is because a hing has moved. All the hinges are adjustable. Usually you loosen the screws and move the door in the appropriate direction and re-tighten the screws. These screws are very tight so you need a big screwdriver and someone big to turn it. Lastly you can purchas a completely new door seal and put it in..
tilt unit backwards,and under hinge side you will see a bracket,undo bolts and transfer to opposite side leaving loose,slide door down ,then on top of door transfer plug to opposite side(if needed)slide door back up and refit bottom hinges/tighten bolts.
handle is just a matter of prising plastic cover of and unscrewing,then refitting to other side.
once you tip it backward its pretty obvious really.
when both doors are closed, do the tops of the doors line up evenly. if not, take a level and make the unit level in both directions the best you can and see if that takes care of the binding that appears to be taking place
The description below is for a gap at the top of the door. Adjust the procedure for gap at bottom by "twisting" the door in the opposite direction.
I'm assuming you don't want to replace the door seal. Open the freezer
door. Stand "inside" the open door and place your foot at the right
bottom corner (looking from the inside). Place your hand in the top
right corner and pull it very slightly toward you. Do this in small
amounts until the gap closes making sure you don't open one at the
bottom.
An alternate method is to warm the gapped section of
the door seal with a hair dryer to soften the rubber enough to allow
the magnet within the rubber to pull the seal gap closed. This has
worked for me numerous times by making small adjustments at a time.
Good Luck
most of these have a hardened plastic female channel thats tough to see . it is a part of the door and consealed under the old gasket. it has a hollow groove . usually the new gasket has a flat side with a dart or double dart piece sticking out . this dart or arrow side runs the entire side of the gasket and smushes into the door groove channel.. usually you start on a corner firmly pulling out the old dart and gasket from the channel groove. clean the old channel with mild detergent and a little brush. wipe down. lightly oil door groove channel with a little veg oil on a rag and get ready to mash the new dart onto the channel all the way around. it takes great finger strength and mashing one thumb on top of the other to get enough pressure but it can be easy on some. good luck .be sure to clean door sill mating surface and wipe with oily Veg oil rag so new gasket stays clean and doesnt stick. it may take a few days to break in and level out. be sure your snug all around when done. lay out new gasket nice and flat in warm room before you start.
Basically they needed to supply an additional door mount for the left hand side of the door as well as the right hand side. Problem now sorted. Poor instructions in the manual didn't help here!
