LG 42LC2D 42 in. LCD HDTV Logo
Posted on Apr 06, 2010
Lg tv turns off after a few seconds, the screen lights up but doesnt even say no source....
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 10, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
485
Points
Hi i have a lg 42lc46 and it wont turn on from stand by it just goes blank and the red light disappears can yiu help
cheers
mike
2answers
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Lg tv model 47LN5400 turns off after a few seconds, the screen lights up but doesnt even say no source....
Main board fault. Replace it. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
My 55inch LG 3D smart tv is not working properly. When you turn the tv on the LG home screen comes on for a few seconds, and then the screen goes black. What is causing this
it's set to the wrong input device ? the one you currently have it pointed to has no input
also it's possible that cable plugged into current input channel has gone bad or become disconnected from it's source
Hdmi cables are unfortunately famous for this as they have no Lock device to keep them inserted into ports
most TV's nowdays shut off if not provided an input for a few minutes
Jun 01, 2015 • LG 55LM6700
When I switch power of the LG flat screen tv on the light go green of few seconds then the light goes red again. Can not even get to menu option when light is red
most of the time you will find the caps on the power supplies are bulged and will not let the set to turn on .must be replaced
My toshiba tv wont turn on
FIRST GREEN LIGHT WOULD COME ON. TOOK IT AWHILE BUT ITWOULD FINALLY TURN ON...NO NOTHING. IT'S GETTING SPARK CAUSE WHEN I PLUG AND UNPLUG IT AT THE SOURCE OF ENERGY IT SPARKS. FUSE IS NOT BLOWN
2answers
PICTURE GOES OFF AFTER A FEW SECONDS. SOUND OF TV
have youtryehave you tried going to menu options and turning off the power save you might try changing the scart cable any interferance will cause the tv to turn of. my little boy often knocks the scart lead on my set an the tv turns itself off when he does this ,. hope this helps good luck
TV screen turned on for only 10-15 secs then self turn off, followed soon after by the tv power another 10-15 seconds later. if i try this a few times screen wont light up at all.Is it the TV Lamp?
1) Can be dust do a good clean
2)Check for the fuse and change it if needed.
3) Capacitor needs to be changed, you'll have to findout which one.
Hope it helps, good luck
1helpful
LG 52SX4D turns off randomly.
My Lg 52"tv turn off and on
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
6helpful
5answers
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
