The release for the battery on my HP laptop won't release the battery, it's like it's jammed...what can I do?
The diagnostic procedures as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source is a battery. If the battery indicator flashes amber or is a steady amber, the battery needs to be charged. If the battery is flashing green and amber, the battery may be defective. To troubleshoot this problem, use the following procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer operates normally when using AC power, go to step 7. If the computer does not boot when using the AC adapter, see the previous subsection, "Total Power Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Your computer may be in a hot environment. Charging the battery in this condition may affect the life span of the battery.
Yes. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. get a new battery replacement.
No. Call HP for technical assistance.
if you need HP battery replacement i can tell you an professional online battery shop http://www.global-battery.co.uk .all batteries here are 1 year warranty and 30 days money back.so you don't need to worry the battery quality.
HP Pavilion dv6000 Battery
Go to where you bought it
SOURCE: HP Pavilion dv2120us Notebook PC battery release latch
My battery latch got stuck in the open position after replacing the battery on HP's DV 6300 series. The battery was thus stuck. I used the 'screwdriver' technique but with a rounded end kitchen knife not an actual screwdriver to remove the battery. It is important to push the knife down a little into the groove at the outer long edge of the battery and pry that outer edge up. AFTER DOING THIS THEN GOING TO REPLACE THE BATTERY I REALIZED THE LATCH PROBLEM OCCURRED BECAUSE I HAD PUSHED THE BATTERY LATCH TO THE OPEN POSITION TO REPLACE THE BATTERY. THIS IS WHAT JAMS IT. TO REPLACE THE BATTERY 'DON'T TOUCH THE LATCH AT ALL'. LEAVE THE LATCH IN THE CLOSED POSITION AND REPLACING THE BATTERY WILL SET THE LATCH IN THE CORRECT CLOSED POSITION, READY TO BE SLID TO OPEN POSITION ONLY TO DO THE ACTUAL BATTERY REMOVAL.
SOURCE: HP Pavilion dv6225us laptop battery release latch
is the latched stuck in the open or closed position? if it is in the open position you may be able to wedge a pick or small flathead and gently ease it out. if it is in the locked position attempt to use one of these same tools to move the latch to the open position. hope this was helpful.
Testimonial: "Thank you. I think I did not have the nerve to use the instruments, because I thought that I would break it. Thanks for your help. It worked. :)"
