IF you have a bottom mount freezer then remove the Ice Maker and four panel screws. The air outlet at the top of the panel can be removed with flat blade screw driver. If you have a side by side there is four panel screws for the metal panel. Once you remove the panel in the Freezer and you will see the Evaporator Fan Motor. Once you can see the Fan Motor, just slide it out and remove motor and replace with new.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
