I will recommend that you download and run the free Windows 7 Upgrade Advisor. It helps find issues with your computer’s hardware, devices that might affect installing Windows 7. Go to the Windows 7 Compatibility Center find direct links to drivers, updates, and downloads.
If you are doing a fresh install then use this link to download your windows 7 drivers http://support.toshiba.com/support/modelHome?freeText=2256719
Depending on your hardware and your current edition of Windows Vista, you can use the Upgrade option during Windows 7 installation to upgrade from Windows Vista to a corresponding or higher edition of Windows 7.
Upgrading is the most convenient way to get Windows 7 on your computer, because it keeps your files, settings, and programs from Windows Vista in place.
If your current edition of Windows Vista can't be upgraded to the edition of Windows 7 that you want to use, you can still install Windows 7 by using the Custom installation option instead. However, the Custom option doesn't preserve your files, programs, or settings. For a step-by-step tutorial on how to perform a custom installation, see Upgrading from Windows Vista to Windows 7 (custom installation).
Make sure that your programs and devices will work with Windows 7
Since your computer is running Windows Vista, it meets the system requirements for Windows 7. We still recommend that you download and run the free Windows 7 Upgrade Advisor from the Windows 7 Upgrade Advisor webpage on the Windows website. It helps find potential issues with your computer’s hardware, devices, or programs that might affect installing Windows 7, and gives recommendations on what to do.
Also, go to the Windows 7 Compatibility Center to see what works with Windows 7 and find direct links to drivers, updates, and downloads.
Next: Learn about the upgrade options for Windows 7.
SOURCE: Has anyone been able to upgrade Acer Aspire 5735Z to windows 7 ?
when i upgrade for windows 7 7600 x84....nd after i crack nd restart i see a screen showin bootmg is compressed...to restart press cntrl alt del
SOURCE: VAIO VGN-NS240E/W PC Notebook: I upgraded from Vista 32 bit to Windows 7 32 bit (...
It is required to install the following Drivers/Utilities in the following order to fix the issue with the functions Keys.
You can click on the link to download the Drivers/Utilities.
Video Driver.
Video Driver Update
Audio Driver.
Sony Shared Library
Sony Firmware Extension Parser Driver.
Sony Firmware Extension Parser Driver Update 1
Sony Firmware Extension Parser Driver Update 2
VAIO Event Service.
Please download each file in the Computer to a folder. After that open the folder where the file was downloaded and double click to begin the installation. Then, please follow the onscreen instructions to complete the intallation process. Make sure that you restart the Computer after each installation. Installing all the above Driver/Utility in the correct order should fix the issue with the Volume/Brightness Function Keys.
Good luck...!!
