I have a WIDL102 indesit washer dryer but the water doesnt heat up and the machine will not progress from the wash cycle to the remainder of the cycle .Is there anything I can do to rectify this ?
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
More than likely that the heater element has failed,
This is usually located at the rear of the washer, remove rear panel, and test with a meter, this is the only sure way of testing it to see if it is o/k.
This problem is normally caused by either the thermostats not working properly or the heating element is the problem.
Both are normally located in the air tube of the dryer down stream of the blower.
unplug it for a few minutes and plug it back in again might be a pain but till you can get it serviced it should delete the fault code and run thru a full cycle. hope this helps a little. Not a true fix just a work around.
I'm a bit confused you posted under Bosch but you specify Indesit, which is a UK machine. The really bad news is you need to replace the timer. the really really bad news is you can only buy the timers from Indesit, I can't find them anywhere in the US. The really really really bad news is they want 117.99 british pounds for them! plus shipping and handling. Here is a link to the Indesit site where you can purchase one.
