I plug the unit into a 120VAC line, turn it on, compressor builds pressure and I let it stop (indicating it's ready).
I ground it to the work, pull the trigger- and cut- for maybe 2 or 3 seconds. Plasma stops ejecting, but device is still on (air flow and fan indicate this). I am cutting muffler pipe, BTW, so it's not that I am taxing the system.
any ideas?
Possibly an internal short in the torch tip... the expendable components failing in the tip will cause the sensors in the machine to register a "no cut" or "free air arc" state and kill the power to the tip to prevent damage to the unit. Replace the tip components and double check the grounds connections.
Hello burnkat. I'm experiencing this problem on our brand new unit (500i). Were you able to resolve your problem. Can I trouble you for some ideas on how you resolve the problem. Here is my email. [email protected].
Throw the unit in the nearest lake and buy a real cutter. Mine lasted (once I got it cutting properly) all of 2 hours. Hobart would not honor the warranty. I will NEVER but Hobart or Miller gear ever again.
