Tricity bendix aw1400w machine will fill and turn slowly but will not wash .also will not spin on spin cycle.will drain water but not go into high spin cycle .drum does turn.motor looks all ok and does turn drum . i can hear a click but then stops beeps and lights flash
Check motor capacitor first.Try moving the drum and see there is no extra friction. If your washer has got braking mechanism check the brakes also. ( I have no idea about this model regarding break)
Runs but spins slowly means the primary clutch is bad. I've found this clutch in good condition with the hub itself burnt blue from overloading, and would not spin all the water out, but everything seemed good other than no speed for spin. I replaced this clutch on top of the transmission and it works perfectly now. I'm not a techy, just personal experience.
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
