Hi, i have a Bosch WFO2865GB that stops before the Spin cycle - intermittently, and flashes the Red Spin light. I can manually switch to off and then to Spin to complete the cycle. Any ideas.
On some Bosch models, E00 indicates that the machine is overloaded. Alternatively, the load is too heavy when wet. The machine can't safely spin the load. You may need to take this blanket to a laundry mat and use their commercial size washer.
Try running the washer when empty. If the error recurs, then the problem isn't the blanket. Instead, the motor is working too hard to spin the tub. This could indicate a problem with the motor or the pulley and hub that connect the tub to the motor.
Replace doorlock and mainboard.
If all five spin cycle buttons flash, its a fatal error.
It depens on which wash button that ligths up.
One of them is doorlock error, the other is main board error
Hi just read your posting.Now when the red spanner light was flashing were there any other lights that were on.If there was then they will be in your cycle selection row.This row has 8 lights on it.Starting from left to right what lights were lit?Is it the 1st and 4th or the 3rd and 7th ---etc---?Please reply with additional information on the questions and I can help you rectify this problem.
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
