Washer fills, drains, fills, drains, & does the final spin. It does agitate during wash, rinse, or dry cycle???
HELP
Thanks
SOURCE: Washer doesn't agitate
sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
Fills, washer drum turns a few times, then drains out. While it's draining the dial is clicking turning around and around and clicking. I have had to stop it reset it and try again......several times the same thing happens over and over!
I finally set it on the rinse cycle and it seems to be doing better. I know it's not fixed, but am happy the cycle will end so the door will open so I can get the clothes out of it.
washer fills with water then nothing. I move the knob to spin cycle and it will spin and drain. The wash cycle does not work. Help
model 2130
Washer does not spin or drain prior to rinsing.
washer will agitate and it will work in spin and rinse cycle but will not fill with water
i have tried to put on other programmes and still i does not spin
