The holes are undersized and the screws are probably self-tapping or sheet metal screws. Try installing a screw into the hole without the hinge in place. That way you may be able to thread the hole easier. Then back the screw out and install it through the hinge. When installing the screw after the hole is threaded turn it backwards slowly until you feel it fall into the thread path then tighten normally. That way you will not start cutting a new thread path or strip the hole too large to hold securely.
