Hey- Let's fix this thing. Several things can affect indicated/actual temperature. The temp probe should test ok across it's lead wires at around 1100ohms. The computer usually shows a fault if the circuit is open, but won't show a code if it hasn't failed completely. The next suspect is the igniter for the oven burner. These can become weak with age, affecting gas flow to burner. Testing igniter is not really possible when it comes on and the part is usually replaced. The regulator is next in line, occasionally causing variable flow to burner. As you can see, quite a bit to consider. On site diagnostics is usually required, but this gives you a start. Installation instructions are available for all parts. Please acknowledge this post if my info and time spent helps you. Have more info if needed. Thanks- Ed
