Maytag top loadind washer. Won't stop filling up. Replaced water level switch, still won't stop. Started water running and unplugged machine and water stopped.
Make sure your drain hose to the drain pipe is higher than the water in the tub if not it will keep running and going out the drain.
Also try taking the hose off the level switch and blow in it to be sure it's not stoped up. If is it won't let the level sw cut off. air should go through it. Good luck
When you unpluged the power and it ddn't keep runing the water valve should be ok.
Hi
If the washer won't fill you'll need to check for the water
inlet hose, the water inlet valve and the pressure/water level switch assembly.
Inspect the inlet hose coming to the washer for any blockages. If the hose is
not clogged then check the water inlet valve for any clogs, if the water will
not even fill for few seconds then certainly the water inlet valve is bad and
should be replaced. You can also use a multimeter to check continuity on inlet
valve. If you don't get any value on the multimeter then you'll need to replace
the water inlet valve assembly. However, if the valve is fine then the
pressure/water level switch assembly should be replaced. Hope this helps...
Please post back if you need more information.
Daniel
Hi
Daniel
