Last night the tv was fine i turned it on this morning and nothing it wont turn on at all no light comes on
If there is no power at all, then the problem imight be the power supply unit but if you don't have the electronic dignosis equipment and the know-how to use it, presume there is not much you can do about, except to take it for service
Unplug 20 minutes. Make sure there is adequate ventilation around the set.
Try with the original manufacturer remote to view setup menu.
Power outages come at night. This sometimes resets the TV and other devices. .
SOURCE: Tv won't turn on
I had a similar problem when there was a power outage or the lights went briefly out. I unplugged the TV and left it for a few days/weeks and then plugged it in and the TV worked. I think newer TVs should be treated like a home computer and put them on surge protectors.
SOURCE: Tv wont turn on worked fine last night
If there is no power at all, then the problem is likely the power supply unit.
The PSU must be tested, then eventually replaced.
