ne of the most common reasons for the freezer to start failing is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them
Did your freezer previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your appliance by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on your freezer. After deactivating the alarm and your freezer has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Hi Denise, thank you for allowing me to assist you!
Did the unit previously experience a power loss? If
the temperature of food rises to an unsafe level, the buzzer will typically sound
the unit by unplugging it or flipping the household circuit breaker. Wait
approximately ten minutes and then turn on the unit. After deactivating the
alarm and the unit has run approximately four hours, the red light/alarm should
go off on its own. If the red light/alarm continues to stay on, the freezer may
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
It may be a malfunction causing this. Check for ice buildup on the lower panel inside the freezer. This will be a sign off a failed defrost component. Check the fan motor in the freezer,is it running? If not,that can be a problem. Feel the compressor,is it running?If not,that can be a problem.
Freezers need a defrost timer to turn it off for short durations so that the coils are not so covered in ice that it can't transfer heat. Make sure that you don't use an under-rated extension cord. Check for any fans that may be blocked from turning.
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting
Need to check the temp to make sure its cold enough.. thats what that alarm is for
