The oil pan is on the bottom of the transmission on your Dyna Wide Glide. To change the gasket start by draining the engine oil and transmission lubricant by removing both plugs on the bottom. Once drained, disconnect the hoses going to the oil pan. Remove oil fill cap, remove two screws and remove the oil spout, pull up on the dip stick cover to remove it. Now, remove the allen head bolts and remove the oil pan. Replace gasket and all bolts. Torque all bolts to 7-9 foot pounds. Refill with oil. Transmission take 20-24 ounces of transmission lube and the oil tank takes 2 quarts 14 ounces of oil if you did not replace the oil filter. Since the oil filter is still full of oil, if you put the full three quarts of oil in the tank, the oil cap will blow off when the oil gets hot as it's overfilled. Good luck
